I had the same symptom, but my problem was a bit different. The gearbox lash was fine. Tie rods were fine. What I found was that the center tie rod arm was loose on the vertial shaft. Appears to have been run over the years with the bolt loose. soooooo, I cleaned it all up, used 2 GM starter motor shims, trimmed to fit the square, new bolt, and it is fixed. I placed the shims on the front 2 flats of the arm, with a short lip on the top to hold in place. These shims were .020 each. I only had to drop the axel, and not the whole gear box (which is a good thing).
No more slop in the steering except for the "normal" lash.
If you are lucky, your problem may be the same.
Took me 2 hours from start to finish to repair including the trip to NAPA to get the GM starter shims............
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
