Posted by pete 23 on May 10, 2009 at 18:13:57 from (173.87.1.12):
In Reply to: 656 no remote hyds posted by han on May 10, 2009 at 05:53:35:
Question, do you have a 3 pt hitch, it has it's own seperate pump and when hitch is not being raised that fluid is added to aux valves. So, that would add some other possible solutions to your problem. When you say you have aux valve function when steering to stops that tells me your problem is in flowdivider however if you do have a hitch that flow from hitch pump should not be affected and still get you a flow to aux valves. What doesn't add up is you say you have aux valve function at low idle. I would take off the large hyd hose from pump to steering flowdivider valve at the valve end and look in valve to see if the orfice disc is in place in valve. I have seen them come out and sometimes just come loose and turn crossways in bore, eiether way, it allows all flow from pump to go to power steering but turning to stops will block flow and then send it to aux valves. Orfice is not a service item but I have made new ones by cutting off a slice from proper size bolt and ( can't remember exact size of hole) drilling a hole . About .125 I think. That could be determined though if orfice is actually the problem.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
