Posted by Tom in Iowa City on May 07, 2009 at 16:44:57 from (173.21.35.134):
1941 Farmall A. The LEFT rear is leaking, such that the rim is getting quite oily and the wheel is also getting oily. I have the rear wheels, rims and tires off. I think there could be only 3 sources for a leak: 1) the left hand shaft, leaking out of the bearing cover, 2) the axle or 3) the pan. A couple of months ago, I removed the pan and its gaskets, cleaned up the mating surfaces, cut a new gasket and replace the pan. In looking at the pan, after removing the wheel, I see a pretty good leak from the left side of the pan. The axle and the shaft seem to have very LITTLE leaking. I know I tightened up the pan machine screws well, so my conclusion is that the pan may NOT BE FLAT ON ITS MATING SURFACE. Do you agree? I will remove the pan and check. I did NOT check for flat when I did the work on it previously. If it IS out of flat, what about using some gasket maker silicone liberally on that area and then replace and tighten? Thanks, Tom
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
