I suppose I'd just check all the wear points on the boom and all the rollers in the track system. Turn it over the side and lift the track off the ground and turn the rollers by hand. They should turn pretty firmly with no roughness. They are usually sealed bearings but the ones I'm familiar with were serviced as a unit. Check for stretched tracks by looking at the hyd. tensioner if it has one. If it's fully extended then that's bad. Check for slop in the swing mechanism by swinging just a little and changing directions quickly but lightly. Check the swing brake by swinging quickly and letting go of the control it should stop very quickly. Check for obvious cylinder leaks and fluid leaks in the engine compartment. Look at all the hyd. hoses. Make sure all the electronics work and work correctly. Most importantly try to use it for a day before you buy it to make sure the thing works well when it gets shook around and hot. Good Luck! ...Randy
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
