rumplestiltskin said: (quoted from post at 06:38:25 05/01/09) I didn’t see that exact symptom in the troubleshooting section of the manual. This is the closest thing:
Condition: Control valve cannot be readily moved from neutral.
Causes/Remedies:
1 – Control valve gang retaining bolts (i.e., valve mounting bolts) and stud-nuts too tight, pinching valves in valve bodies. / Loosen retaining nuts and bolts. Re-torque to 25 ft-lbs.
2 – Control valve linkage binding. / Check and free up all hand levers and linkage.
3 – Orifice in upper unlatching piston plugged. / Dismantle control valve, clean thoroughly, renew gaskets and seals.
4 – Control valve and body scored. / Replace old valve with new. Check system for dirt, abuse or cause of failure.
I hope this helps (my money’s on #1 above).
Mark W. in MI
Thanks a bunch! My bet (hope) is on #3, actually. I havn't laid a wrench on those since I've owned this monster, but I had just topped off the hydraulic oil about 15 minutes prior to the failure. I may have stirred up some gunk between the filter and the valves. It's just kinda weird that it worked flawlessly one second, than nothing. I removed the linkage and worked the valve by hand. All I can get is neutral and down. There is something very solid keeping the valve lever from moving past neutral to the up position. So... either it's dirt or a mechanical failure inside the valve. Gonna find out tomorrow morning.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
