Posted by ScottyHOMEy on April 29, 2009 at 15:08:21 from (70.105.244.253):
In Reply to: farmall super c gas posted by mitchfarmallsuperc on April 29, 2009 at 13:30:10:
If it's right under the fuel tank, that's what's called a sediment bowl. The float bowl is the bowl of the carburetor.
They're pretty readily available through most parts outlets.
It's sometimes hard to tell where the leak is coming from. It could be the thread between the bowl assembly and the tank but usually isn't. More common is for it to be the gasket between the glass and the meatal, or around the valve stem.
Before going looking for a new one or a gasket, you might try just tightening the compression nut, which is the hex nut that would appear to surround the stem (the part you're turning) of the valve. It won't go far or take much, and you may find that all you've accomplished is to make it so tight that you can't turn the valve and that it still leaks. If that's the case, you can learn how to repack the valve (quite simple actually and a neat little project, and while you're at it would be a good time to replace the bowl gasket and the screen inside the top of the bowl) or go ahead and thread a whole new bowl assembly in.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
