Posted by chadd on April 25, 2009 at 22:41:39 from (4.142.198.55):
Well, I tore into our 1940 Farmall M today. It had 60 psi on cylinder 3 and 80 on the remaining cylinders. The head gasket was blown out between 3 and 4. The problem is that cylinder 3 also has at least 3 or 4 sets of corrosion grooves where the piston had been sitting in one spot for a long time with the valves open. It also appears to show evidence of discoloration of the metal, but it could also be rust damage. 2 and 4 have less pronounced grooves as well. Three of 4 pistons are covered with a blanket of prickly black carbon (burning oil?). The grooves on cylinder 3 are deep and easily catch your fingernail. All 4 bores have no remnants of the crosshatching on the cylinder sleeves. Additionally, I can wiggle the pistons in the bore at least 1/16 inch if not more. I was wondering about the following: 1) Does the above sound like grounds for a rebuild? (just want to make sure I am not being overly fussy; I don't want to part with more money than I need to) It is a work tractor, so it needs to be dependable.
2)It has 4 inch thin wall sleeves with what appear to be original aluminum IH firecraters installed under a 6336-DD Kerosene head. Can I still get a set like this (along with all of the gaskets, pre-overbored 4" I.D. sleeves, mains etc. for an inframe, where is the best place to get them, and what will the damage (to my wallet) be? 3)Is there anything I should know or check to make sure I don't rebuild it and wreck new parts? 4)It overheated idling for 15 minutes on a 70 deg day in neutral last year, which triggered the head gasket failure. I since found out that there was not thermostat installed, so it definitely wasn't the problem. The radiator and hoses are all new and the water pump belt was new and properly tensioned. It has no coolant ending up in where it doesn't belong, so I am wondering if anyone has an idea what would have caused such a severe overheat. Only thing that springs to mind is water pump. I just don't want to repeat this incident again in a year.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
