Posted by P and R Pete on April 24, 2009 at 06:46:07 from (173.86.52.206):
Here's the only pics I have of my oil pump-
My situation was that I had an oil gauge that ranged from 0 to 30, and was reading '10'. My service manual says that an SA should have pressure between 50-60, so I guess I don't have the original gauge.
The '10' was worrying me, and my clutch was slipping, so when I went after my clutch, I did all new rod and main bearings while I had the engine off, as well as what I did to the oil pump, so I can't say exactly what made the difference with my oil pressure, but now my (wrong) gauge stays absolutely pegged on 30.
But I had no discernable 'slop' in the gears within the oil pump, but as you can see, the pump cover was worn, so I had a machinist mill it flat again.
I had two VERY thin paper gaskets that came with the engine-set. With one gasket, the gears were slightly binding, so I went with two, and 'called it a day', with happy results with my oil pressure. I've read plenty on this forum about guys carefully checking end clearance between the gears and the cover with plastigage, etc., so you'll have to listen to them, or get other advice. Those gaskets were, supposedly, .006 thick, so the difference between one or two wasn't much, and worked for me.
I'm not sufficiently experienced to be able to tell you why your oil pressure is (suddenly?) zero, but I'd be real careful running it until you find out why. I've heard that can happen with a 'spun-bearing', but there is a pressure-relief-valve in the oil pump, which is a piston with a long spring, and as the oil pressure rises above what the engine can use, the spring depresses until a bypass hole is exposed, and the excess oil is bled right back into the pan. It seems possible to me that if that spring is broken and the piston has dropped beneath that bleed-hole, your oil pressure will plummet.
Another problem I found with mine was that the original gasket had maybe a half-inch blown out, which won't help the pressure either.
If you don't know how to get the pump out, it's very easy, once you drop the pan. There are two bolts on the right side of the engine, you can see them right above the pan and maybe 6" directly below the oil filter canister. Remove those two, and with some twisting/wiggling, the assembly will come right out. Disassembly will be self-evident.
Be prepared to have to replace the old gasket(s) if you take the cover off. Mine was pretty decayed, what wasn't stuck.
If you don't have a service-manual picture, let me know and I'll post one.
You mentioned the 'heat' after plowing. I use mine to pull a brush-hog on hilly ground, and I was having trouble with the antifreeze boiling when I used it, to where I had to keep topping it up because it was going below the vanes in the radiator. During my overhaul, I added a waterpump, with the problem solved. Others here say it wasn't necessary. Worked for me.
I don't know what causes the blow-back out your breather. Hopefully someone else will explain that, and we can both learn.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
