Posted by charles todd on April 23, 2009 at 19:48:34 from (205.242.95.133):
I gutted the wiring harness on my 62 F504 last year (it had burnt up more than once). I also added a 10SI one-wire to the mix. I removed the two headlights and the rear light to restore. I sandblasted, filled the pitting and holes, then sanded, painted, and made up new wiring. I could not locate the original style light body connectors so I used what I had.
When I installed my Koyker 220 loader (FEL) the original lights were about useless. So.... I built some light mounts for the loader. I used 2 pin plugs to disconnect them when I remove the loader. I know, some of the viewers are thinking, one limb and that is toast! The uprights are 1 1/2" square tube, 3/16" wall and the base is 1/4" flat held on with 4 - 3/8" stainless bolts per side. The lights are 55W each so I ran them through a relay to keep from burning up the switch (new).
I appoligize to some with slower connections, this may take a while. Got several pictures to load up.
Front View of Left Front Light
Rear View of Left Front Light
Front View of Rear Light
Rear View of Rear Light
Front View of Loader Lights
Side View of Loader Lights
Loader Light Base Mount w/ Stainless Bolts
New Fuse Block, Wiring, and Relay...
Delco 10SI One Wire Atlernator and Custom Aluminum Billet Fan Spacer
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
