Re: Hydraulic valves
Posted by mkirsch on April 23, 2009 at 13:35:24 from (64.80.108.55):
In Reply to: Hydraulic valves posted by Clean John on April 23, 2009 at 10:40:29:
The single-action loader cylinders are not built to take pressure on the top side. If you try, you will only get another snoot full of oil.
Here's what you do:
1. Run a hose from one valve's work port to a T, then to the two lift cylinders.
2. Run a hose from the same valve's other work port to a return on your hydraulic reservoir.
This way it will just pump the oil straight back into the reservoir when you let the loader back down.
This also leaves your second valve available for other things like a hydraulic dump bucket.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
