I did a complete rebuild on my super c engine. The old clutch was shot and starting to get into the lining rivets. I reassembled with a new clutch disc and orginal pressure plate which worked fine when I tore it apart. I used a small amount of grease on the end of the driveshaft to assist it in spinning inside the pilot bushing.Clutch pedal has been adjusted as per the book. It runs great but will not disengage enough to get her into any gear. But if the clutch is pushed and held and then the engine is started it will not move as it should. My only thought was that the pressure plate and or flywheel has enough high spots to prevent complete disengagement due to the new thicker clutch lining. I figured on maching flywheel and replacing pressure plate. Wondering if you guys have any better ideas before I have to split it again ? " Super C is the tractor in question" As always thanks in advance for your help.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
