The spark advance should ground the mag [at the mag: lever way up, maybe 1:00 facing it] when pulled way to the left, it sure doesn't hurt to trade a bit of motion to be on the safe side of turning it off - this wouldn't affect starting, only potentially a bit late at full operating RPM [where you'll have it to the right].
It'd be interesting to post a question on the best time frame and duration for seating the rings, and general break-in: probably get as many answers as # of members activly posting! :lol:
Probably somewhere between 20minutes and 20hours of light loads
(just driving it around I'm of the mindset of a few light trips around the yard [closer to the 20minutes or maybe an hour], at least one long enough to get some temp [at least 130's like a hot water faucet] in the radiator check it over, then a good load for an hour or two)
then give it a load of 1/2 to 3/4 rated
(plow, disk, thresher [if there are enough people and bundles to run an hour straight], or dyno or power-eater)
and get the radiator up to boiling [on water, might want a gauge if you already mixed antifreeze, no idea though of the right number - say 220 constant?] for an hour or better.
I've heard of just covering the radiator and driving it around good and warm, and even claims that quality rings will seat without working it - but logic to me seems that getting it to a solid operating temp and under load before the sleeves glaze is the best chance for the rings to seat. Of course, I wouldn't need to count toes, and maybe not even complete both hands, for the number of engines I've given new rings - so I'm probably over cautious.
For that first or second crank start every time, there are likely some sweet spots - but for starting a few cranks, unless wayyyy too late (like 45degrees back down the stroke), or early enough to kick (or the mag grounding yet in the start position: not the case if you have spark), you shouldn't need that much prescision there.
Same with priming fuel: I do like the cups to see if the carb is cooperating, else just choke for the first couple cranks (on 'loose' engines, I've often used Bob's trick of "mag off"-"choke on" first 4, choke off-mag on the next one, but seldom over a couple pulls with choke (and not even turning off the mag) with good compression) should be enough if the carb [and, of course, everything esle :lol: ] is cooperating.
Good luck! Hope you have more fun than frustration or fatiqued muscles. 8)
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
