Posted by spiffy1 on April 18, 2009 at 08:58:13 from (70.41.137.72):
In Reply to: Hard-starting 15-30 posted by ScottyHOMEy on April 17, 2009 at 19:21:39:
No offense taken, only confused because with modern view [which I'm using] vs. classic view sometimes I think I misinterpret the reply trail.
If you have good compression, you should be able to rule out the rings and valves (which still could be set wrong if good cold and erratic hot, but doesn't sound like the case).
As just noted, you'll have to listen for the impulse (the E4A you can see and hear, but have make sure to manually trip it before cranking), it could be stuck; but if it's running rough it sure could be coil or condensor or points instead or as well as the impulse.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
