Unless it is an electronic regulator, it should make no difference whether it is used with positive ground or negative ground. Electronic regulators use diodes and transistors and thus are dedicated Positive OR negative ground.
What makes an electro/mechanical regulator positive or negative ground in the material used for the contact points. A regulator dedicated to either positive ground OR negative ground will have contact points made of different materials for longer life. A regulator designed for both positive ground AND negative ground will have both contact points made of the same material which results in a shorter working life.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
