Gordy, hmmmmmm say the tractor battery got installed OPPOSITE from the correct polarity (likely at 6 volts was Positive ground originally) that would make the ammeter register bass ackwards as you indicate......
Buttttttttttt if the genny were correctly re polarized it could still be charging fine, its only that the ammeter would then show discharge when shes running at fast RPM
Sooooooooo what does the ammeter do when shes running is the obvious question???? Cuz if it swings to - discharge and more so as RPM increases, she may be charging !!!!!!!
Put a voltmeter on the battery and just sitting there NOT running Id expect around 6.3 volts but then when running at fast RPM ifffffffff the battery voltage rises to the 6.5 to 7 or so range SHES CHARGING AND YOU SIMPLY NEED TO REVERSE THE AMMETER LEADS to make it register correctly. HOWEVER you may wanna take it back to the original Positive ground,,,,,,,,,,Polarize the genny BEFORE you start it up,,,,,,,,leave the ammeter as is and it should now register correct.
Whatever you do POLARIZE the genny (see instructions in my procedure below)
Below is a URL link to my Non Charging Troubleshooting Procedure
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
