Mark, a simple ohm meter continuity test can "make sure its bad" as you asked butttttttttt it cant tell you if its good !!!!!!!!! i.e. just cuz it passes the simple low voltage ohm continuity tests dont mean it wont still break down at high voltage and under temperatire conditions.
The primary as measured between its lil + and - terminals would be around 1.25 to under 2 ohms on a 6 volt coil BUT if its an open (near infinity ohms) circuit its BAD for sure.....
Use a test lamp or voltmeter to make sure theres hot battery voltage on the coils input (NOT distributor side) when the ignition is turned on cuz shes never gonna fire otherwise......
Then place a 6/12 test lamp on the coils other (TO distributor) side (other lead to frame ground) and it should lite up when the points open but go dead off when they are closed...
Remove the cap to make sure the points are gapped correct and open n fully close as the distributor shaft rotates......
A COMMON problem is the points are burned or pitted badly so check that and clean/file/buff them as necessary and check the gap n try again n see if she fires?????
To isolate if its a cap or rotor problem ONLY,,,,,, remove the coil wire from the top of distributor (leave coil end intact) n place that bare end 1/8 from tractor steel n turn on ignition n crank engione n see if a spark jumps that coil wire gap ??? If so but NOT out any plug wires once cap is replaced, its a cap or rotor or plug wire type problem
CHECK THE POINTS FOR GAP AND CLEAN/FILE N TRY THEM OR REPALCE IF BAD BURNED OR PITTED THAT MAY BE ALL THE PROBLEM
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
