I'm assuming you have the transmission driven PTO, not live PTO. Any oil leaking around the seal would be from the transmission. It's an easy job to replace the seal. Just unbolt the bearing retainer that contains the seal and slide if off taking care not to pull the PTO shaft with it. You can then press the old seal out and a new one in. You will need to clean the PTO shaft really well and make sure no burrs or rough spots on it that would damage the new seal before you slide the new seal on. You will also likely need a new gasket for the bearing retainer. This seal change can be done without draining the transmission. You just need to park the tractor on a fairly steep slope so the transmission fluid goes to the front and away from and below the level of the PTO shaft.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
