Posted by CNKS on February 06, 2009 at 18:42:59 from (216.144.104.128):
In Reply to: h timing posted by redplower159 on February 06, 2009 at 14:56:43:
Set TDC on # 1 as Bernie says. If the rotor does not point to #1, remove the distributer, rotate until the rotor points to #1 and install in that position. Do not try to "compensate for the meshing of the gear", (whatever that means). The distributer will mesh properly without moving the rotor from #1. After the gears mesh and distributer is inserted all the way, rotate it conterclockwise. Remove the coil wire from the distributer cap (switch on), hold end of wire 1/8 inch from the screw/nut on the dist that the small wire from the coil attaches to, rotate dist clockwise, viewed from the rear, until you get a spark. Tighten the distributer. It is timed. As a final check rotate engine one full turn, and check for spark again with the coil wire. If it does not start after that, it is not timing.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
