Posted by ScottyHOMEy on February 03, 2009 at 06:14:14 from (64.222.201.63):
In Reply to: SUPER-A HDY ARM posted by KEITH SHAW on February 03, 2009 at 00:45:14:
Keith, IF you have a three-arm system, the outer arm on the left should actually pop right off after you remove the nut. It's keyed to the shaft so it needs to come off straight and may take just a little pop with a prybar, chisel or other wedge to start it, but it's a tapered fit (would remind you of a trailer axle spindle) and once its free it should come right away. Be sure to remove (and later replace!) the key, as it might obstruct getting the inner arm off the shaft.
As for the inner arm, I've only had mine off as part of a complete overhaul of the block, so I'll caution that what I'll suggest MIGHT work with the block on the tractor. The first piston link you come to (the one on the left) controls the left inner arm. (The shaft for the outer left and the right-side arms rides on bushings inside this shaft.) Just looking at the parts catalog, once you have the outer arm and key off, the only things holding the inner arm in place are a two-piece bearing (similar to a pillow block) and the wrist pin through the piston rod and the clevis ears on the shaft. The bearing cap can be removed by removing the two bolts holding both pieces to the block, after which the bottom half should slide when you eventually pull the shaft. The wrist pin has smaller pins on the end that ride in two braces -- the one to the left is a double-dogleg affair and the one further in (to the right) is like a wider triangular arch??. If you can remove the bearing and those two braces, you can get the wrist pin out and the shaft should be free.
The inside of the shaft is normally greased and it may be dry or stiff, so that it won't start off easily. In that case, you might try pumping some new grease in then heating it some to pull it away. Like the outer arm, it may like some light to moderate tunking (NO beating!) to get it started off. Take note that one or both of the two bushings for the inner shaft may come away with it along with the inner half of the bearing.
Odd thoughts . . . You should do what you can to clean things up first so you can see where you're going. And of course, it's tight quarters in there, so I'm not sure you can get wrenches in there to get things apart.
If that's the case, Hugh's suggestion of taking both shafts out is likely the way to go. You could try that with the block on the tractor by removing the right-side arm and key and the right-side bearing (a single piece, unlike the two-piece affair on the left) as you did on the left. You may still have the issue of access to get the wrist pin out for the right-side piston (and maybe still the left-side as well), in which case, you'll likely have to remove the controls and the manifold from the pump and pull the whole affair, block and all, and do the rest on the bench.
The four arm shaft will be similar, except that the shaft in questionis two pieces, left and right, keyed to each other so that they operate together. Still, the left side should come away after the outer arm , and the bearing and wrist pin for the left inner arm have been removed.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
