The most likely cause is a worn out MCV pump. Turning all the way to end of steering travel will cause the the steering hydraulic system to go to maximum pressure. If the pump is weak it will not be able to supply enough pressure to open the steering relief valve. This will cause a lack of pressure to the brakes and TA. If the TA is in the forward position the high side clutch pack will release causing the TA to pull only on the low side sprague clutch resulting in a momentary loss of power to the wheels.
A bad side effect of a worn MCV pump is loss of lube to the differential and range transmission main shaft. Excess flow from the MCV pump is used used to lubricate those parts and since the steering has priority for the oil flow, the differential can be starved for lube even if the steering still works OK. That is why it is important to replace the MCV pump when steering/TA problems first start showing up at low idle. Almost all of the differential failures I have worked on could be traced back to problems with the MCV pump and lack of lube.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
