Posted by TX656 on January 26, 2009 at 20:14:33 from (71.48.166.51):
I don't think that this change caused any required change to my carb settings.
However, at the same time as I fixed the flapper I also adjusted the valves and retimed it. This is going to sound crazy but it runs so much smoother and got so much quieter after the valve adjustment that I have this feeling I lost some rpm's on the top end? At wide open throttle and no load she runs just a hair over rated PTO rpms.
I checked the governor adjustments and took out 1 turn of the link as per th manual with no noticable effect.
I need to ask my FIL or wife to watch the RPM's while I manually work the throttle plate to see what rpm's are without the governor in the loop. (although watching carb/governor linkages/springs work it it doesn't seem like anything is restricted or blocked.)
I also need to hook it up the disc and pull a couple passes to see if the power was affected or if its 'all in my head'.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
