Posted by Dellbertt on January 24, 2009 at 17:12:34 from (209.172.21.12):
JimN,
On my 300U with the rear mounted forklift the TA works fine and I used it a lot when loading bulk boxes of sweet corn.
Your explanation of the TA basics operation in a previous post was well done and cleared some fog.
I have a question concerning rapid engagement going from low speed to high speed. For the purpose of the question let’s assume the tractor is moving on level ground with constant throttle setting.
When pulling the TA lever rearward into low speed I never have a problem doing it rapidly with any concern of possibly hurting the system. But when letting the TA lever go forward into a higher ground speed it always gives the feeling similar to pushing the clutch forward for initial movement on a JD A so I always move it slowly letting the tractor speed build up gradually. A few times my hand has slipped off the lever when moving it forward because, as you know, once released the lever moves forward on its own, and the tractor leaped forward with a jolt that did not feel good for the system. When going from low speed to high speed it seems that if I push the TA lever forward rapidly it would be the same as just letting my left foot slip off the main clutch pedal at start up from a stop to get going.
I’ve done it this way for about 10 years and the TA system has not seemed to change any.
Some where in this is a basic question about letting the TA lever move forward rapidly or should you play it like a clutch when going to a faster ground speed, I hope I didn’t muddle it up.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
