Re: pto adjustment on 300u Here is my take. Look at the linkage and be certain it has no lost motion, there are pins and woodruff keys in the system that can be loose. Fix if found. Place the lever 1/2 the way between the latching points of on (up) and off (down). Remove the little dome cover on the PTO box. Under this will be two lock nuts and two adjusting screws. The PTO should turn by hand (engine off). Loosen the lock nut, and turn the front screw in until you can feel the shaft start to resist turning by hand. Loosen it just until it will turn free, no more. Do the same for the rear adjuster so that it can rotate free, but no more. The front adjustment is the drive adjust, the rear is the brake adjust. If the screws are down level with the adjustment lock nut top, the bands are worn, and will need replacing, or relining at a clutch shop. That is not quite the book way, but I have used it many times. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
