Posted by Janicholson on January 17, 2009 at 16:42:50 from (64.83.227.252):
In Reply to: 460 out of time!!! posted by A.M.'s 861 on January 17, 2009 at 15:59:02:
Take out the plugs,and ground the coil high voltage wire against the block to prevent high voltage from finding you. Put your finger, or a rubber hose, in the #1 hole (closest to the radiator) and turn the engine By hand, or starter bumps, until air is felt coming out of it. this is compression stroke. Turn by hand from here until the timing marks are aligned. The distributor cap now needs to be removed to see where the rotor is pointing. It must be pointing to #1 exactly. This assures the spark is getting to the correct cylinder. Then check the remaining wires to assure the correct firing order. If this is OK I would next see if there were good strong suction on the intake when cranking. Place your hand over it to feel the suction. If these check out, see if the fuel supply is getting to the carb. Let us know what happens after this. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
