Posted by biggerred on January 14, 2009 at 19:19:22 from (74.177.51.224):
Just got a 53 Super M (stage II)and am learning all the differences from the 52s. This one has the live hydraulics with the res. under the gas tank where the battery once was. It has a valve purched on top of where you use to fill the old belly pump. This model has what I assume is a second res. where the old pump once was. Does this valve configuration bypass back into the upper tank as well as a lower tank? Bare in mind this is factory stuff, not some cobbled up job. The valve is loose at the base where it goes into the lower tank, and I need to disassemble all this to tighten things back up. There is no guidence at all in my IT manual for this type set up.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
