Posted by Janicholson on January 02, 2009 at 21:22:42 from (68.112.156.69):
In Reply to: farmall h clutch pedal posted by Patrick J Cummings on January 02, 2009 at 19:14:54:
Ac CNKS indicates set the freeplay at a bit over an inch, then it should release well. Free play is done with hand pressure as the pedal is pushed down it will begin to get resistance from the pressure plate and get much harder. This is the beginning of the release motion. THat distance is the freeplay measured from the pedal contact point to the platform edge where that contact point normally rests. Remember it has no syncros, and straight cut gears. If when you have it in gear stopped, and (holding the clutch down) put it in neutral, it should not start to spin again making grinding. If it does, and the freeplay is right, the pilot bearing might be getting sticky, (lube it) or the disk might be warped a bit, or the splines might be holding the disk against the flywheel some. Good luck, let us know the outcome. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
