The block has some small dings in it around where the #4 sleeve fits in the block and it is lower than the other three. This is why I believe the problem is with that cyclinder.
I put new rings in it last spring and when I put the head back on it, it did not seal. When I first got the tractor I had the same problem and I tried some Stop Leak in it and it stopped the leak.
If I run it for a couple of hours, I will get about three tablespoons of antifreeze out of the drain and the oil starts to look nasty.
Before I put the head back on, I took it to work and it is flat to within about .003 if I remember correctly.
I do not have a heated area to work in and I do not want to take the head off this winter and I do not want to wreck this engine, after putting the new rings in it. Thank you Steve
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
