Posted by Janicholson on January 01, 2009 at 18:09:33 from (64.83.200.187):
In Reply to: Need Wiring Diagram posted by Willy Hall on January 01, 2009 at 16:16:47:
The lighting wire going to the L terminal can be connected directly to the load side of the Amp meter. The Big screw terminal on the Alternator goes to the same terminal (load side of amp meter. The #2 terminal goes to the big screw terminal also. The #1 terminal should go to a wire attached to a oil pressure switch (purchases at a NAPA store, this switch has two terminals and is open when there is no pressure) "T"ed into your oil pressure gauge or line to the gauge. The other terminal of the switch is connected to the positive battery terminal at the starter switch (where the supply to the amp meter is connected (that big post on the switch with the battery pos cable hooked to it.)) THis setup causes the alternator to start charging as soon as the oil pressure is up., and stops charging when the engine is off. No diodes or other stuff needed. I would put a 70 amp Fuse link in the wire going to the Amp Meter from the start switch. As mentioned below, do not connect anything to the ignition. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
