Posted by Janicholson on December 29, 2008 at 09:01:06 from (64.83.200.187):
In Reply to: FARMALL TRADE posted by FRED IN VT on December 29, 2008 at 08:29:21:
The oil pressure issue is probably just a simple near no cost repair of the oil pump end frame that gets warped and leaks. A pan gasket is needed. Pull the pan and oil pump (or just the cover from the pump) and flat sand it so that is seals. the gaskets are very thin, and used for shims. thin aluminum pop can can be cut to make new if needed. The clearance between the end gear and housing should be .0008" to .001" . It is a pretty common issue. There are no cam bearings in the engine, so the mains and rods are the only major repair for pressure loss from bearing wear. The oil pressure relief valve could also be sticking open, but I would check the pump end frame first. Fred with respect, turn off the caps function. It makes very difficult reading on some computers. (it is also considered shouting) JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
