Interesting, Most engines, while in operation, do not touch that area of the cylinder at all. Thus there is no reason for deposits to "wear" off. But if all had the Sooty deposits, and very much if, the tractor had been operated under load for at least 4 or 5 hours prior, I would suspect it was using oil pretty heavily. If the tractor was not brought to temp in the last few times it was run, I would say it was very normal. Personally I think diagnosis by pulling the head may have been (with respect) premature. Diesels (especially the options with the gas start/diesel run engine) can be diagnosed to high reliability fault finding with the head on. Particularly the fuel injection system. What to do now: turn the head to a position so that the intake and exhaust runners face up on the bench (with the valves and injectors, and not the spark plugs, are in place). Tap each valve with a plastic hammer to make sure it is seated (crud can get into the face seat during disassembly). Then fill the manifold runner to each valve with diesel fuel. If fuel runs out the valve to head interface, the valve (or seat) is bad. If after an hour some diesel gets through I'd say it is OK. Some will get through the guides, if dramatic, the guide is bad. If it leaves the runner, but ends up in the water jacket, the head is cracked at the runner. Set the head so the spark pluge are up. Fill the compression relief chambers with diesel. the third valve should also hold the fuel as above. I would have the injectors tested at a good diesel shop, (if it had been still together, cracking the fittings on one cylinder's injector line at a time to find the miss, followed by compression checks and swaping injectors from cylinder to cylinder would have been my method of testing. Best of luck. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
