If you can put it in all gears, and when the clutch is let out, nothing happens, the clutch is probably out. Secondary possibilitys would include: ta clutch and ramp and roller are both out, Splines on clutch shaft are torn off, Clutch hub damper springs are toast. There are ways to see inside, but not fix anything. Also a major failure of the final drive (ring/pinion, or bull gears) will also give this symptom. Look into the trans to see motion through the fill hole. Good luck, JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
