Posted by Janicholson on December 20, 2008 at 13:38:11 from (64.83.205.193):
In Reply to: M stuck in 3rd gear posted by Jerry RV on December 20, 2008 at 13:27:24:
There is a pin that holds the shifter into the tower casting. The pin is under two small pressed in caps. Remove the left cap with a drill a nd sheet metal screw to pull it out, then drive the pin out the other side with a punch. Pull out the lever. Put a big screw driver into the hole and move the shift rails until they line up. the middle rail will be moved forward, it needs to be moved to the rear to align. The tip of the shift lever probably needs to be welded up a bit and reground to fit the rails better. the pin driven out must also be renewed if worn, (most are) Match the pin with the shank of a grade 8 bolt, and make one. Put the plugs back in and a dab of RTV on the hole to seal it from grit and weather. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
