Re: Soldering advice
Posted by Jim Becker on December 18, 2008 at 09:36:03 from (71.252.139.51):
In Reply to: Soldering advice posted by DRC on December 18, 2008 at 08:45:40:
I suggest that when you try it, you have the radiator filled with coolant up to the point where the core is completely filled and the liquid is just into the bottom of the upper tank. Do not have it high enough to cover the back side of where you need to solder the bracket to the tank.
The coolant will keep the areas that don't need repair from coming unsoldered. If the coolant is too high in the tank, you will not be able to get enough heat into the areas that you are repairing.
You can add more coolant before working on the overflow tube.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
