You probably just broke one or both "ears" off that make the slot you use to screw it out. Dave is right as long as the opening is clean it should run fine. I had my H carb open and found one of the ears broken off. I drilled it out with a tiny bit (don't recall the size) and put the smallest easy out you can get in it. It had a little varnish around the threads but came out fine. I put the new jet back in, and couldn't tell a bit of difference - but I bet I dropped $25 into the drill bit, easy out and new jet.
If the opening isn't buggered up I'd leave it alone. My 2 cents.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
