Posted by Brian2 on December 09, 2008 at 15:22:49 from (76.64.56.151):
Well, as usual I just can"t leave well enough alone, mind you, if I didn"t keep tinkering it wouldn"t be as much fun!!!
Anyways... If you guys recall I successfully got my Super A to charge using the voltage Cut out on the system. It is a 6 volt, positive ground. On high charge it was putting out 10 volts, on low, next to nothing. Everything was fine. However, I came across a inexpensive NOS 6volt, 3 post, Delco Regular and thought "what the heck", maybe it will help prolong the life of my battery. Tonight I installed it, F to the Field, A to the Gen. and Battery to the Amp meter. When I first started it up and ran at 3/4 throttle, she went to 10 amps (switch position made no difference, which I guess is correct). After a couple of min I noticed the gauge indicating a little less of a charge, which again I figured was correct. I tried the lights, the amp gauge dropped down to about 3 amps, again no problem.. Turned the lights off, she jumped back up to about 8 but was slightly shakey. I then gave it a bit more throttle, the amp went up to about 10 then just dropped. I"m not sure if it was still charging or not(might be a little??) but basically it just dropped. I then lowered the throttle to idle, she started charging at about 4 amps. Full throttle, jumped to 1o again, then back to basically nothing. Lowered the throttle she jumped back up to 3 or 4.
So, anyone have any ideas on why it"s doing this? Is it correct?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
