Those Delco starters will sometimes hold themselves engaged if the engine does not crank over fast enough so that compression pushing a piston down can release some of the starter load. When the starter stays under load the spring in the solenoid may not be strong enough to disengage the drive from the ring gear. This causes the drive to hold the plunger in the engaged position causing the starter to keep cranking. If you do not find any electrical problems this is most likely what you will find. This is much more common with eight cylinder engines than a four cylinder engine.
From your description it sounds like you are not getting enough cranking speed on the engine when you are trying to start it. Make sure your battery is in good shape and your cables and connections are good. It would be good to know how much draw you have when cranking. If everything checks out electrically excessive draw will indicate a mechanical problem with the engine.
I have run across some of those German engines that had such a minor seeping of antifreeze from the sleeve o-rings that the lost antifreeze was never noticed in the oil. A small amount of antifreeze in oil can cause a "sticksion" problem. The oil gets so sticky that it takes a great deal of force to start to turn the crankshaft but after only a partial revolution it frees up and turns almost normally. With the starter out, try turning the flywheel to see if it takes excessive force to start to rotate it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
