Okay, you're basing "weak spark" on assumptions. Spark is not where the power comes from. The BANG the spark creates is where the power comes from. If there's too much, or not enough, fuel in the fuel-air mixture, the bang will be weak, and the engine will not produce power.
If you want to verify the spark quality, remove a plug, put it back in the boot, and lay it against the engine block. Have someone hit the starter button while you watch the plug. Make sure the tractor is in neutral because it could start on 3 cylinders. You could disconnect the remaining 3 plug wires from their plugs to prevent that, just remember where they came from. I'll bet the spark is bright blue, which is perfect.
Unfortunately, your local advice, the one that's telling you to "go up a heat range" is just guessing. Whether that's because he's just taking your word on what's wrong, or he's trying to get rid of you, or he's trying to sell you more parts, or he's just clueless, is irrelevant. The heat range of the plugs is neither the cause nor the cure for this problem.
I believe you have a fuel delivery problem. The tractor won't start unless you "starve it for fuel" and will "flood" when you give it any choke at all. A carburetor service (I despise the word "rebuild" because all you're replacing is a few gaskets) including disassembly, cleanout, reset the float, etc. is in order.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
