Posted by ScottyHOMEy on November 30, 2008 at 18:02:49 from (70.105.234.190):
In Reply to: super c rebuild posted by jonathan mirgon on November 30, 2008 at 16:57:26:
Having a battery ignition, you can use a tach like the old dwell-tachs that hook onto the terminal of your coil that runs to the points in your distributor. I got mine years ago and guard it closely, but they're still available. Not all of the newer ones let you choose 4-cyl, so it's sometimes necessary to take a reading on 8-cyl and double it.
I also use a laser tach. If you're starting out clean, you can get a patch of the reflective tape to stick onto your crank pulley.
On greasier motors, I've put a patch of the tape on the PTO shaft and adjust until high no-load idle turns the PTO at just under 600 RPM.
Just a note, all my books for the SuperC, and the Ser # show high no-load idle as 1815, which is 110% of the rated working (loaded) RPM of 1650.
I don't think you're gonna unglue your motor job by turning it up to 1850. I mention it just in relation to using the PTO shaft for a laser tach. 110% of 540 is 594, so that's my target. 1850 is more like 112% and works out to about 605 on the PTO. Your motor speed will fluctuate enough that 600 is not a bad compromise for either target.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
