Posted by Janicholson on November 29, 2008 at 06:59:04 from (209.191.204.169):
In Reply to: Re: water in cylinder posted by IndiRon on November 28, 2008 at 19:14:42:
The sleeves in that engine are dry (pressed into the cast iron of the block full length contact. Rarely do they come out easily with the piston in the cylinder, as the piston ring rust has swelled the ring and sleeve so that they are tight. Some crack the sleeve, and cast bore as well. Getting the piston out can (in extreme water corrosion) require it to be removed in pieces. Drilling out the top just inside the rings with a circle of holes, and cutting down beside the pin with a recipro saw or similar. Good luck, JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
