Set the timing according to spec as described in your operators manual. That is #1 at TDC, with the distributer installed so that the rotor points to the #1 terminal. If you wish, after doing that you can adjust by ear to the highest rpm. At idle these engines sometimes sound as if they are laboring unless you make a SMALL adjustment. However, I think your problem is the carb is too lean, possibly due to a partially plugged main jet, which is not adjustable (provided your carb is similar to the ones on the C113/123 engines, yours is a C135, same basic engine). It needs to be disassembled, soaked in carb cleaner, possibly overnight, blown out with compressed air, and a new kit put in. You say it has only one adjustment, if so that is the idle mixture jet, just turn it in or out until the engine runs smooth at low idle, not wide open throttle.It should also have a screw for the idle speed. Be sure the float is adjusted to specs.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
