Posted by Janicholson on November 15, 2008 at 14:52:49 from (66.173.50.167):
In Reply to: McCORMICK DEERING-W4 posted by janice on November 15, 2008 at 08:03:12:
Going in through the PTO hole works. There are two big bolts between the bull gears holding them to the splined axles. (drain the oil!!) Then loosen the head of the bolt on the side being replaced by blocking the wrench handle, and turning the wheel! I would block up the bull gear with metal shims under it to the case, to prevent it from moving when removing the axle, it makes putting it together much more satisfactory. Put a block (metal) between the head of the loose bolt and the head of the other one, and use the bolt as a screw jack to push the axle out of the bull gear. It is tight, it is greasy, it is a braille situation when your hand is in there, but it can be done. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
