F20 can use straight unleaded gas- old manuals suggest 1 cup of engine oil to 5 gallons of gasoline. The engine doesn't run fast enough- cam duration isn't open enough to cause exhaust valve seat erosion problems. IHC Super H,Ms may have some erosion if run steadily at 1800 RPM, Cases and AC late 50s noted to also be susceptable- this from a Wallaces Farmer articles early 80s when unleaded became standard- 1500 RPM seemed to be the start of extra erosion. Ford Ns were not at risk as Ford had used stellite seats to start and JD twins didn't run too fast and valve timing didn't have long duration. F20 governed 1000/1200 RPM- just add a bit of oil to gas like old manuals suggested. Oil for winter? Try 10-30 to ease cranking- F20 is more of a splash system with rod bearing trays and crank ball bearings instead of plain bearing pressure lube. the 10-30 will flow and splash a bit easier than straight 30. RN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
