Posted by Bob M on November 12, 2008 at 08:25:39 from (151.190.254.108):
In Reply to: M steering problem posted by Dardo on November 12, 2008 at 07:49:48:
The half moon gear can be swapped for a full circle gear.
However getting the old gear off the pivot shaft can be an SOB as you have discovered. It’s on a tapered spline and is usually stuck on pretty well. Sometimes a suitable puller can break it free. However I’ve always had to resort to “brute force” to get ‘em off:
1 - Jack the tractor so the front wheels are off the ground (jack from beneath the clutch housing, then crib for safety).
2 - Remove the front wheels/lower bolster assembly at the flange (4 bolts beneath the fixed bolster) and set the front wheels aside.
3 - Invert the castle nut and thread it down so it’s flush with the top of the pivot shaft (to protect the shaft threads during the next step…)
4 - Now use your biggest hammer (I use an 8# sledge) and give the top of the shaft a few good licks. With luck the gear will pop free.
5 - Now remove the castle nut and slip the gear off. (Crib beneath the pivot shaft first so it won’t fall out – the shaft is heavier than it looks!)
Tip: Check the pivot shaft bushings for looseness and replace ‘em if necessary while you’ve got the front end apart. Any radial play at all - particularly at the upper bushing – will result in sloppy steering even with new worm and gear installed!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
