Try this if it fixes it you know what the issue is. Use a different 12 volt battery to provide ignition voltage. (take the wire coming from the switch off of the coil. and hook a battery up with jumpers to the coil, and ground (same polarity as the regular battery) then try to start it using the regular battery. If it starts right up, the issue is voltage drop to the coil when cranking. Heavy o gauge battery cables might make it fire, or a 12volt coil designed for use with a external ballast resistor. If you choose the new coil, you need to put a single pole switch across the ballast resistor so you can manually take the resistor out of the circuit when cranking, then put the switch to off allowing the resistor to be used. If you are volt meter friendly, the coil needs 10 volts for enough energy to fire when cranking. If it is less it will be difficult to start. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
