Posted by Ted in NE on November 08, 2008 at 09:39:07 from (74.85.105.88):
In Reply to: 560 hydrualic problems posted by farmallguy3 on November 07, 2008 at 17:11:30:
When you removed the fast hitch you need to remove the rod that runs along the left side of the trans. cover. Lock the linkage that the rod was hooked to so it can't move. With the engine running move the lever that you used to run the fast hitch carefully one direction or the other untill the hyds come off high pressure. Then tie the lever so it can't be moved. This will center the teledepth valve spool. It is possible that the gears in the valve have broken teeth. Will have to be repaired. Look at the end cap on the valve that runs the fast hitch{back cap}. Could have a cap screw in it. This was used to center the spool if it ever had a single row beet harvester on it. Had to remove the fast hitch to mount the harvester
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
