Posted by Janicholson on November 02, 2008 at 17:57:56 from (66.173.50.118):
In Reply to: Cultivators posted by TimWafer on November 02, 2008 at 17:14:39:
In a nutshell: The cultivators are effective on row crops, but pretty slow for today's field sizes. If you are playing with 10 acres or less they will do fine. Two levers with adjustment notches bolt to the front of the rear axle housing (we take off the drawbar first, i think most do because it is not possible to use the tractor for utility purposes with the cultivators on it ) Two pipes with metal brackets for the cylinders attach to the lever handles, one on each side. S shaped steel bars with a cross pin in one end go in the holes in the bottom of the hydraulic pump, to guide the cylinders. On the front cultivators there is a 4"X4" angle iron that crosses in front of the bolster just below the grill it is attached to a pair of plates bolted to the front bolster casting, one on each side. The pipes mentioned push on the top of the cultivators on each side to raise them. The rear unit covers the wheel tracks, and tills the middle of the row where the front tires run. There is also an accessory tined rake like smoother that is used on the back to break up ridges, but if it is not there, no problem. it takes two people about an hour and a half to do it when they know how, it will take three or more if it is the first time. Be careful driving into the setup not to puncture a sidewall on the front tires on the sweeps Shields for preventing the sweeps from covering seedlings are valuable. The cylinders are connected to the front hydraulic ports on either side. Good luck, They work but seem like a Rube Goldberg affair. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
