Yes, the bolt is regular right hand thread. And yes, you can take the drive shaft out without splitting the tractor. You have the drive coupling loose and that is probably the hardest part. To get the shaft out, take three (every other one) of the bolts out holding the cluch pressure plate to the flywheel. There should be three holes in the pressure plate that have no bolts in them. Put the bolts you took out in those holes and tighten them down. This will compress the clutch spings and relieve the clutch plate so it can move enough that you can tilt the drive shaft down and get the shaft out. It's been a while since I did this, so there may be a little more to it, but it should be pretty obvious as to what to do. It may be necessary to remove the cross shaft that works the clutch fork to get enough clearance, but I don't think this is necessary on the H. If you have to remove that cross shaft, post back for more instructions.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
