Posted by Randy-IA on October 25, 2008 at 09:08:54 from (207.177.83.174):
There doesn't seem to be many ways to seal the shifter ( getting a car type shifter boot that will slide down tight on the shifter and zip-tie or hose clamp the top tighter is one way ) but has anyone tried to seal the cover bolts with soft copper washers or flat rubber washers? The split lock washers would have to be removed. Is there enough movement/vibration of the cover that would cause these to fail quickly? The rubber probably wouldn't be a good choice due to the torques required on the bolts . I wouldn't want to use silicone around or under the heads of the bolts just because it would be a pain to clean up at a later date or wouldn't seal properly trapping more water under the head of the bolt. Just some thoughts. ...Randy
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
