Posted by Janicholson on October 17, 2008 at 11:38:38 from (199.17.6.128):
In Reply to: Super A Wiring posted by Jay Poole on October 17, 2008 at 02:59:23:
A starter relay used for this purpose is about twice the volume of a Kodak film can. usually on or near the starter. It will have at least 3 terminals on it, Two large terminals, and one (or two) small. The small will be closer to one of the big terminals than the other. I will call this big terminal Relay term-1. If it has 2 small terminals, you will not use the one labeled "I", and the S terminal will be close to the Relay term -1 mentioned above. Attach the battery positive to this big terminal. Connect the other big terminal to the starter motor heavy terminal. From the small terminal (Might have an S near it) a #14 wire goes to one terminal of a SPST momentary contact push button switch. From that switch's other terminal a 14ga wire connects to the amp meter load side. The other side of the amp meter is connected to the battery with a 10ga wire that goes to the Relay term-1. (I like to put a 40 amp fuse link in this wire as a system fuse, it can be purchased at NAPA)
The exciter terminal on the alternator (Numbered 1 on the alternator)is connected to a pressure switch "T"ed into the oil gallery where the oil pressure gauge line is connected. This switch turns on with pressure, and has two terminals. One cannects to the alt #1, the other connects to the Load side of the amp gauge. The big wire (10ga) from the big alt terminal goes to the load side of the amp gauge as well. The #2 terminal on the altconnects with a small #14 wire to the big terminal on the alternator (It is very short. Good luck, JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
