c-man's sounds like a new rebuild on the motor so I think it's safe to eliminate hot chunks of carbon or the burrs at the top of the cylinders being hot enough to make his engine diesel.
Cam timing can be off. Though it's still out there as a possible cause, I'll assume for now he got that right or never monkeyed with it at all.
Running an engine with the ignition timing retarded can easily cause it to run sufficiently hot to diesel at shutdown, especially if it has been run up to speed. In my exerience with older, timing is the notthe only, but the most common cause of his problem, and is only more common with the lower octane fuels we have these days as compared to what was available in the fifties.
That is not to discount your advice about his idle speed. If his valves are at all leaky, the angular momentum left in the motor could cause it to turn far enough after shutting down the igintion to draw in more fuel that would ignite. But I tend to doubt that a new rebuild with good compression and tight valves in proper time would run on that far.
My exception was not to your advice about the idle speed. It was only to the statement that timing might have nothing to do with it.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
